Old 15th January 2014, 07:39 AM
If it's toughened then it will almost certainly 99.99% explode into a million bits. Even with a diamond cutter.
Laminated should be ok if you do a cut accutarly on both sides andthen carefuly break and cut the membrane layer.
Plate. Simple enough to cut but I would not want it in any car I was driving.
Old 15th January 2014, 08:44 AM
rpjg1975 rpjg1975 is offline
Chatting to my mate last night and he said that autowindscreens will cut any shape windscreen providing you can give them a template.....unsure of price but could work out cheaper than hassle and hospital appointments
Russ
Old 15th January 2014, 11:29 AM
If you want toughened glass and its a flat panel then make a template and take it to a glazier.I had one made for my boat for next to nothing. Toughened glass will always have a kite mark or manufacturers mark and is heat treated(tempered) after cutting and edge grinding. Dont even consider trying to cut it.
Old 15th January 2014, 07:39 PM
Company called Spartan do plant glazing in the NE Kev (No everybody not flowers)!
Worth a look.
Old 22nd February 2014, 11:47 AM
Gonna start getting ready for this summer now and first thing I am going to look at is a home brew version of a 3" straight through cherry bomb using stainless wool instead of the traditional glasspack.
there is only 1/4" between the inner core and outer body this is due to the heat shield I have being only just under 4" dia so everything has to be quite compact, you will see what I mean over the next few days
the raw materials
Old 22nd February 2014, 12:22 PM
Looks interesting!
Just to warn you, I packed my exhuast with wire wool to get through IVA and it disintegrated into dust after a few hours of driving!
Old 22nd February 2014, 12:52 PM
It better bluddy hadn't John as it is the proper stainless stuff from an exhaust company.
