Old 12th February 2014, 07:03 PM
Mondeo 1.8 clutch disk is 220 mm in diameter and Sierra is 215 mm, that's all the difference there is. Should work. The fitment of the release bearing depends solely on the clutch cover used.
Old 18th February 2014, 10:09 AM
you need the mondeo pressure plate to fit the std zetec flywheel and most want to buy a kit with a new friction plate that fits the type9
so you end up needing a mondeo mk1(mtx box) clutch kit and a longer type9 release bearing (ct133 iirc) as the fwd clutch pressure plate are short throw
