Old 21st February 2014, 09:18 AM
Drilling out the 30mm material on your top front wishbones is not really an option as I have no safe and secure way of clamping them in place, a complete wishbone is just the wrong size for the vice. If you want the sleeved adjusters you can find the parts on ebay, be warned though the outer tube where you weld the arms too some times distorts it making the inner section a bugger to get back in. Doing the job correctly would involve machining the outer ring under size,welding the arms to it,leave it to go cold then ream it to size. Unless you are planning on adjusting the ride height between track and road use 8-12 times a year how often will you have to move them?
