Old 23rd February 2014, 05:27 PM
waynes world's Avatar
waynes world waynes world is offline
I have found this place with a good, i think, ratio calc
http://www.solemnwarning.net/transmission/?
I am trying to work out what ratio i need and if the Suzuki SJ T box will be good ratio wise as i reckon its going to be fine for the power.
Old 24th February 2014, 02:51 PM
I am serious to get this going this year as i have sorted a good dry work area out now, well asap as my wife has said i can turn the conservatory into a work shop
My idea is to use what ever engine and G box ( not decided yet, so then i have been looking into using a Suzuki SJ T box ( seperate ) these are good for 200+bhp and same torque in a 1 ton 4x4 fun car, just the casing lets them down but i can beef that up easy enough, they have no built in diff, i was told i need to get a T box on a road car that has a differetnial, why i dont know??
I see it that if the front and rear (LSD ) either sierra or Impreza diffs will do that job.
I will still have to work out how the set up will be as the outputs from the T box are on the off side so i am seeing if i can offset the engine/G box slightly to give space for the drive shafts.
So what you think on the T box and Diff use?
Old 27th February 2014, 12:37 AM
you need a central diff or you will get wind up from both fronts traveling a grater distence than the rears and it will soon go bang!
off road style 4x4 usualy have a thing called a free hub (over run clutch) that you lock out on the rough stuff
Old 27th February 2014, 09:51 AM
Dualist's Avatar
Dualist Dualist is offline
Hope you got that in writing bud
Old 27th February 2014, 01:41 PM
So thats put the end to the SJ T box, oh well, i am thinking what else i can build now anyway, or restore.
Oh and Dualist, i have been im touch with my solicitor and getting papers written up
