Old 6th March 2014, 06:49 PM
Gaz ones come allready drilled with grub screw in.
Old 6th March 2014, 06:53 PM
So........
there is no need to try and cut the side panel around the coil over and wishbone ends? Other than for aesthetic reasons?
Has anyone had a car through an IVA without panels in this area?
Old 6th March 2014, 07:26 PM
Hmm, my Gaz shocks have just such a grub screw in the locking colar for the spring seat.
Perfect for mashing the threads when you forget to undo the grub screw when you try and adjust the height.
Old 6th March 2014, 09:09 PM
There should be a little nylon/delrin stub under the grub screw so that doesn't happen.
Old 6th March 2014, 11:10 PM
So........
I think it's just for aesthetic reasons. Our panels are like the ones fitted to westfields
Old 7th March 2014, 10:03 AM
As David say's. There is nothing stopping you placing something behind all the front suspension on the chassis to cover all the bits and pieces in there.
Old 7th March 2014, 11:10 AM
So have you just left it open? If it would get through IVA I wouldn't be bothered about covering it up.
Old 7th March 2014, 06:20 PM
Yes I'm going to keep them open and put some edge trim on the end of the panel.
Any photos to show how your build is progressing?
I will hopefully. Post something up soon. Just waiting for my cycle wings before the big unveil!
Old 7th March 2014, 06:57 PM
Well I'll be doing the same then with my panels.
Look forward to your update. My car looks pretty much the same tbh, I've been doing little IVA things. I plan on making everything I can that's on the car atm IVA ready before going any further.
Old 7th March 2014, 07:24 PM
Originally Posted by K4KEV View Post
The actual shock itself is in an area that is not tested with the dreaded 100mm mushroom. The trapazoidal shape created inside of the wishbone frames is exempt.
Not strictly true - the top of the shock protudes out of the exempt area and has the potential for ball contact!
I stuck driveshaft gaitors over the top of mine:
Interestingly my adjusters don't have any kind of locking mechanism and they passed
