Old 10th March 2014, 07:24 PM
You don't find many rivets in a wing it's 99.99% bolts.
Old 10th March 2014, 09:25 PM
You are joking of course rivets are used extensively throughout most aircraft both wing and fuz unless of course you are talking about composites and very modern aircraft .....if you are not joking then where do you get that figure from
Old 10th March 2014, 10:12 PM
SeriesLandy's Avatar
Option 1..
Old 11th March 2014, 09:13 AM
Only bolts in the wing hold spar to fuselage and elevator to wing and also
flaps,boatload of cherry rivets hold the important bits on.
Old 11th March 2014, 12:57 PM
Cropper Cropper is offline
If you want to be accurate, large civil airliners have their wings held together with interference fit "bolts". Smaller aircraft use Rivets & composites use bolts & glue!!
Hope that helps
Old 11th March 2014, 03:12 PM
Cirrus SR 22 is plastic !
I think you mean what holds the wings on,they are still riveted together.
A lot have "Jesus bolts". Jesus is that what holds that on.
Old 12th March 2014, 12:52 PM
I can assure you that large aircraft wings are held together with interference fit bolts, they are hammered in & have nuts put on the reverse side to a set torque. Having worked on the A380 wings I think I can assure you this is correct!
