Old 29th March 2014, 12:20 AM
after contemplating for a while and looking at the options for the rear diff on the mx5 I really liked the idea of talons diff cover!! thinking about heat transfer I studied the diff and thought could I bolt it in my lathe and shave 5mm and make a plate to sandwich in between so I gave it a go seems to of worked and you still use the old ali cover so correct oil level and breather are in place
Build pictures
