Old 16th April 2014, 05:06 AM
Default Instrument cluster connector
Hi,
I'm keeping the original instrument cluster from my donor (Sierra 2.0i DOHC 1992), but the previous owner of this car just made a big mess of the connector to this cluster. Cables there have been cut, soldered, re-cut, got connector crimped on some of them, added a long "chocolate block" connector, all of this very close to the cluster's connector which does not allow me to re-cut and make nice and clean connections as I want to do. It is a proper mess, and I have problem reconnecting everything correctly. The best think for me would be to change this connector. Do you guys know where I can get hold of a connector with a sufficient length of cable (in order to be able to re-connect it nicely to my loom) in the UK? Or perhaps one of you who didn't keep the original instrument cluster from his Sierra donor and could sell me the connector from his original loom?
Thanks in advance.
