Old 6th May 2014, 06:51 PM
Enoch Enoch is offline
If they are only 470mm wide I think I can make them fit I made a prop today - it's not the final one as I have no way of balancing a prop but it is made to the correct dimensions. I have been able to measure the space in the tunnel and can change it to give myself an extra 40mm or s, which should be just enough.
Thanks for the info.
