Old 9th May 2014, 08:17 AM
Working on an over edge tub cover at the moment. Around the roll bar and where the tub joins the sides has some less than round edges so this will cover them up. The big hole allows access to my filler cap.
Very fiddly trying to get it round the roll bar and struts in a sane way. I will velcro or popper the gaps together.
Old 9th May 2014, 07:18 PM
Fits quite well over the tub and bits. I have ordered some red zips for the in betweeny bits instead of pins...
Just need to trim round the edges now and popper it down.
Old 10th May 2014, 08:58 PM
Well that went well.
Old 11th May 2014, 11:30 AM
Dualist's Avatar
Dualist Dualist is offline
That's well tidy
Old 3rd June 2014, 05:25 PM
Sent off my IVA form today with the following still to do.
Replace all fluids.
Check fuel tank grounding.
Brake compensator hole.
Valve Cover breathing hose re-route.
Pedal rubber/grit.
Maybe swap steering wheel.
Seems doable.
Old 3rd June 2014, 06:35 PM
bowt time anawl John
Old 3rd June 2014, 07:21 PM
Replace all fluids.
Pedal rubber/grit.
Seems doable.
I'm hopefully going to send mine off soon. Which forms do you need to complete and where so you get them from?
Old 3rd June 2014, 09:58 PM
I wonder how long it will take before you get brassed off with dribbling unleaded over your beautiful red vinyl ?
Old 4th June 2014, 06:54 AM
Individual Vehicle Approval (IVA) forms
I sent form IVA 1C and IVA 4 along with copies of the donor V5, major components invoices and a a small 30ish photo log of various build stages.
Old 4th June 2014, 06:57 AM
Leather.... I'm used to gloving up and grabbing the towels before I fill anyways so I think it will be ok, just got to be careful.
