Old 14th May 2014, 01:43 PM
Just been doing some quick reading up on this, and it seems to be a very muddy area...
Basically you need 8 points from the table below (and the chassis has to be 5 of those).
If you can't add up 8 points for your car it's classed as radically altered and you need an IVA and a new registration.
What isn't entirely clear is what level of chassis modification is allowed before it counts as no longer being original.
If you're just adding a couple of extra brackets to the chassis you're probably ok.
If you start cutting bits out of the chassis you're probably looking down the barrel of an IVA.
On a kit car however I suspect it's going to be very hard for anyone to prove or disprove which bits are original and which aren't, and I doubt anyone would even try.
Old 15th May 2014, 01:34 PM
waynes world's Avatar
waynes world waynes world is offline
Thanks guys for the input and to agree with what my thoughts were on this, i have always seen it as no chassis can be altered at all, i have now been told i will need to cut one of the cross memebers out and moved.
I think i will just get a MX5 back end and see how it needs to go.
Justa thought, if somebody knows about these cars which is a Dutton Melos, it is registered on the V5 as a 1986 on a Q plate. if they see a MX5 subframe they could question about it as they were built back then, or any other car i think with that set up, oh the Jag did though i think.
