Old 31st May 2014, 10:05 PM
Unless you have access to either a hydraulic guillotine or a good quality plasma cutter save your self a lot of bother and just buy a chassis plate kit from Gillham online, life is just too short to spend that much time cutting it with an angle grinder. A little tip get 2-3 sheets of A4 paper cut all the chassis plates and arrange it on your sheet, it will make the cutting order easier to work out.
