Old 10th June 2014, 08:52 AM
they look well tidy Kev
Old 10th June 2014, 10:45 AM
E-Bay or Heath Robinson Ltd .
Old 13th June 2014, 09:24 AM
Default Thank you!
Thanks Kev for the spin in your roadster last night!
Im still grinning from ear to ear.
That is one seriously ballistic car.. I now think i need to strap a turbocharger on my engine now!
Old 13th June 2014, 05:31 PM
Arf.....they aren't half bad are they !
Paul.....both
Dave.....glad you enjoyed it mate ....it is a little on the evil side, and you can't help smiling from whichever seat your in.
Old 22nd July 2014, 07:11 AM
I am afraid in my quest for "Mo Farrah" av gon an blawn me terbo ..... my boost had been set way too high and the bearing could not cope, so I think I might have to detune my engine until I can build a more robust set up.
Tub is beyond repair as compressor wheel is damaged, so I bit the bullet and ordered a chinese copy as there is no way I can afford even a reconned tub, came yesterday so I will get some pics of it up later.
Old 22nd July 2014, 08:29 AM
Can you get high capacity/high pressure oil pump for that engine,if not shim relief valve for a bit more oil pressure to feed turbo and rest of engine better.
Turbo's fail because people never let them spool down after hard driving and it was probably well used prior to you,bit of a bugger after all the graft
Rebuild kits are available but would you trust something that's got to run at silly revs and heat without being set up properly, No.
Old 22nd July 2014, 10:11 AM
I have a nest of new turbo`s here Kev. They came in a job lot of other kit. I will take some pics and if there is anything you fancy let me know.
