Old 25th June 2014, 06:53 PM
Not too bad really. I'm looking at mine as a final to-do list as the worst outcome.
Old 25th June 2014, 07:10 PM
Peter-C Peter-C is offline
Smile
Only got the emissions to sort now. Overall I think its been a good day, even the self centering worked !! I can definitely see light at the end of the tunnel. Thanks to the many on this forum who have helped me along the way.
Old 1st July 2014, 10:49 AM
Unhappy
Having problems with the engine dying on me. I can run it for half an hour - slight misfire now and again. But when I tried to take it to a garage to test the emissions after about 1/2 a mile it started to badly misfire and finally stopped, as if you'd switched the engine off. I checked for loose connections and swapped the carb ( Pierburg ). Gave it rest for a few days, tried it again today, ok idling for 15 mins. As soon as I got to about 1/2 a mile, stopped again. Help !!!.
Old 1st July 2014, 11:24 AM
Sounds like something is getting too hot, fuel pump or something electronic too close to a header or rad hose?
Old 1st July 2014, 04:55 PM
I don't know why I didn't check the fuel filter, it was full of Sh***. Couldn't adjust the mixture, screw was rounded. Swapped carb and adjust mixture until the car ran ok and made the trip to a local garage. Set up mixture now HC reading is approx 439 instead of the previous 2291. Now time to book the retest.
Old 7th July 2014, 11:17 AM
Default Registration form
I phoned Swansea last week to enquire about which forms I needed. The chap said V627 and V55/4. Is form V55/4 for a Q plate and V55/5 for age related ?
Old 7th July 2014, 05:51 PM
SeriesLandy's Avatar
V627/1 from tinterweb. Your car not donor goes in the top right.
V55/5 for age related. Order online only and takes 2 weeks.
