#431
It is but it was made into a trailer a yonk ago. New trailers are supposed to be IVAed now.
Cheers Stot
1.6 Mazda B6 : Garrett TBO339 : 420cc WRX Injectors : FMIC : Microsquirt V3 : LC-2 Wideband : Toyota COP : 1.8 ATB LSD Build Started Jan 2013 : OTR Aug 2014 : Still OTR June 2024 |
#432
Some of you may remember me promoting wearing eye protection when grinding when I posted a pic my eye ball with a metal shard in it. Well I was wearing eye protection this time when the 0.8mm blade shattered,
like a hammer to the face. I converted an old welding mask after that. Cheers Stot
#433
ouch !!!! glad you are ok .we do tend to take H&S a bit lightly when working on our projects but that shows you how easly it can bite you back.
full face sheild looks to be on the cards for me ![]()
My build diary is at http://thailoz.wordpress.com/ |
#434
Ahmen to that,had an 8in disc blow up on me once, luckily had full face mask hat and gloves on but still made me nearly incontinent.
Be carefull out there.
#437
Well at least it wasnt in vain.
Cheers Stot
1.6 Mazda B6 : Garrett TBO339 : 420cc WRX Injectors : FMIC : Microsquirt V3 : LC-2 Wideband : Toyota COP : 1.8 ATB LSD Build Started Jan 2013 : OTR Aug 2014 : Still OTR June 2024 Last edited by Stot : 30th June 2014 at 10:10 PM. |
#438
#439
We never listen though, even to ourselves.
On the trailer, I just weighed trailer with car all strapped down and it comes in at 902kg including the ramps and has 82kg on the nose as loaded. Well happy. Cheers Stot
#440
Well I'm just back from the IVA and...... I have a small list of things to do.
There were a few nuts that I had forgotten to re-tighten by the end like the adjusters on the caliper end of the handbrakes but the main fail points were Radius on the front and side repeaters. Radius on the top of the front shocks headrest height in its lowest position is too low. Air filter needs securing. Everything else they liked. Retest on 23rd. Not a bad one really, a weekend of work. Cheers Stot
