Old 14th August 2014, 09:42 PM
Originally Posted by TalonMotorFabrication View Post
It's fairly easy to set both the front and rear to zero toe you just need a 40ft ball of string. Tie it so that it makes a big loop and place it about 200mm up from the ground around all four tyres, the string should be tight against the edges of the tyres. Get on your hands and knees and you should see the difference in the gaps between the string and the edges of the tyres.
its only easy if it's adjustable, which on the rear it's not.
