  #34
Old 25th August 2014, 08:37 PM
I decided from the beginning to run the column over the scuttle rather than through the pedals to make it less congested. The adjuster on the column gives 550mm floor to wheel center to 650mm floor to center , that will make it easier to get in and out
It also makes for an easy route for the steering shaft with no nasty angles, it all clears the headders by about three inches and the uj`s will have an easy time. The sharpest angle is 30 degrees. just need a bearing block mounted off the top chassis rail to carry the steering shaft.
