Old 14th September 2014, 09:21 PM
Numplumb Numplumb is offline
Default ECU light
I bought my donor parts already removed not a donor car, and it seems that I don't have a warning light for engine fault warning so I have 2 questions
1) does anyone know if I could add a wire to the ECU to fit one, the circuit diagrams I have show the wire as being black/yellow there isn't a wire of that colour in my ecu connectors I do have quite a few empty spaces though.
2) If it is possible does anyone know which connector and position to connect it to.
Regards Mick.
Old 14th September 2014, 11:43 PM
Regards Mick.
Are you using an mx5 donor?
If so all you need is a jumper wire and an led in the diagnostic port. There are lots of posts on YouTube showing you how
Old 15th September 2014, 10:33 AM
Hi David thanks for your reply but isn't that just for reading fault codes, I was thinking more of a light which comes on when ignition is turned on and then goes out unless there is a fault.
Regards Mick.
Old 15th September 2014, 10:44 AM
Regards Mick.
There isn't one of those on mine. Are you using a late model MX5?
Old 15th September 2014, 11:24 AM
I think the indicator LED does light up when there are codes to read If you dont jumper it into diagnostic mode too and just have the LED in there.
As a check you can unplug a sensor or two, coolant temp at the back of the engine or O2 sensor while running and see if it lights up.
Old 15th September 2014, 01:24 PM
No I think it is a 93 or earlier I just bought the parts and I bought a dash off EBay but I didn't realise that it was from a Eunos in KM so I bought another one Uk spec the difference is the Jap one has engine fault light in place of rear fog light but my loom is Uk spec so I just thought maybe add a light if possible
Regards Mick.
Old 15th September 2014, 01:45 PM
Regards Mick.
I meant the one you add to the diagnostics port. You add an LED/bulb between FEN and + and a jumper wire from TEN to ground to read the fault codes, but I think if you just add the LED it will light when there are codes to read. You could extend the FEN wire into the dash to light the dash bulb.
