Old 15th November 2014, 04:28 PM
garyt garyt is offline
well been outside its cold and damp but moving forward with the sc install got the sc mounted (1 upper brace to make) got the inlet side sorted out and in, remade the exhaust manifold aka the mx Miata turbo one and the downpipes sorted.
so next up mount the intercooler and pipes and a belt tensioner (a bit of headscratching with this one) then onto the wiring oh hum got boxes of multi-coloured spaghetti sitting here.
Gary
Old 23rd November 2014, 05:19 PM
got a bit more one this weekend fuel filter and lines sorted, s/c tensioner made and in place, intercooler mounted and plumbed, boost sensor mounted and a wee drop of paint on the s/c outlet. made a start stripping back the engine loom to relocate a couple of things. working back towards the scuttle ... mmm... fun ...
Gary
Old 23rd November 2014, 08:02 PM
Is there going to be some sort of scoop to push air into the IC?
Old 23rd November 2014, 08:41 PM
Hi , was really trying to avoid that if at all possible, mounting the s/c lower should reduce some of the heat transfer issues the mx5 conversion has, the airflow from the rad /fan will create some negative air pressure behind the I/c and I will fill the edges, so will see how that goes and if IF and only if, I will look at some sort of scoop duct directly for the I/c but at the moment don't really want to go the scoop route.
Cheers Gary
Old 15th March 2015, 07:42 AM
got a wee bit done cos the sun came out and wife is away visiting family for a bit so been collecting making bits so hopefully can get a bit of a push on
Old 15th March 2015, 08:58 AM
Not half foggy in your garage lol .....nice colour scheme ..its different.
Old 15th March 2015, 09:04 AM
Yeah sorry about the quality or not of the pics
Old 15th March 2015, 02:49 PM
dubzter's Avatar
dubzter dubzter is offline
looking good Gary
Old 28th March 2015, 06:03 PM
well absolutely frozen but happy messed about finishing the manifold and got some alterations to the wiring (but nae finished that one yet...) firewall made battery in a tempory earth , connected the instruments turned the key and ............ nothing.
went over and over it, had coffee and more coffee. so went and rechecked it all and found 1 connecter off the back of the main fuse block, took it off to put through the firewall. reconnected it and the battery ..... BINGO lights on the dash and engine turns over. so T time. with a big smile
so hopefully tomorrow will run some tempory wiring to the pump and add a couple gallons of petrol and see if we can get fuel pressure and if so we will go for a start up
Old 29th March 2015, 02:24 PM
ok so after working out ive fuel engine cranking but nothing else panicking that its an ammobiliser fault , I found 2 wires that should be connected so joined them and away she went a splutter and died an adjustment on the throttle cable to the 2nd tb and she is running.
absolutely awesome to hear it now I need to finish the cooling system and tidy all the tempory wiring.
https://www.youtube.com/watch?featur...&v=ZkL9IioRExQ
if this link disnae work go to you tube and enter "its alive Haynes first start up "
very very happy
