![]() Rosco, do you know what engine you will be fitting? Most engines won't fit with the diagonal chassis rail in the engine bay on the drivers side so it is usually removed. Also if you are considering fitting a zetec then you may want to modify the rear up-most chassis member in the engine bay as you can't fit a standard thermostat housing with the chassis member there. You can buy aftermarket thermostat housings but they are stupidly expensive and don't work very well.
1.8 Silvertop Zetec (ZX6R Carbs + Megajolt) + Type 9 My Build Blog: http://www.haynes.co.uk/forums/showthread.php?t=2736 - Last Update: 31st October 2020 Total Spent so far: Stopped counting ![]() |
