![]() Changing the chassis spec ie tube wall thickness and replacing 19mm with 25mm is what will effect rigidity of the chassis and that was what was done to a chassis that was built by Saturn to be raced,2mm wall tube instead of 1.6mm and it was very rigid and handled well.
you may find improvements in suspension mods like spring rates and dampers,also anti roll bars or more drastic inboard suspension so the dampers work at a different angle.
