Old 7th January 2015, 08:53 PM
onedayTM onedayTM is offline
Default Rivnuts?
This may sound daff! is it steel ones for steel and ali for ali?
Old 8th January 2015, 03:15 PM
Agreed. I've used ally ones and already I had 2-3 bolts stuck with the rivnut turning in its place.
Old 8th January 2015, 10:35 PM
ok cheers for that
Old 9th January 2015, 01:45 PM
MikeB MikeB is offline
There a compound you can put in to stop the reaction between metals, we use to use it putting steel helicoils in to ali tank hulls. Can't remember what its called though!
Old 9th January 2015, 02:15 PM
Squirt of WD40 into box section would not hurt either .
Old 9th January 2015, 08:17 PM
do people use ali because they are easier to form then?
tony
Old 10th January 2015, 07:26 AM
tony
Probably because they're cheaper. It is how to build a car on a budget
The ali ones are sh!t though. They're quite soft and it's very easy to damage the threads in them.
I'd only use stainless if I was starting again, or even better use weld-in inserts instead.
Old 10th January 2015, 08:31 AM
tony
Steel rivnuts over m6 are almost impossible to form with a hydraulic tool.
To limit galvanic corrosion you can use something like duralac, but its designed to go between plates rather than on a threaded insert, not sure how well it would withstand rotation whilst its drying.
Old 10th January 2015, 12:38 PM
I used steel zinc plated rivnuts to fit the bodywork. I put a bit of Sikaflex around all of them before crimping. So they also are a bit bounded too and not only crimped (which will make them even more difficult to get loose) and I believe it makes a protection layer/sealing. The excess is easy to clean with alcohol afterwards. It cheap too.
2014-07-08_10-28-13 by Voucht71, on Flickr
Old 13th January 2015, 11:23 PM
Ste W Ste W is offline
Mastinox it's called. We use it in work on Eurofighters
http://www.silmid.com/products/masti...-27-mil-p.aspx
