Old 15th January 2010, 07:36 PM
Tatey's Avatar
Tatey Tatey is offline
I have to say i would be tempted to do this, but it means buying a new regulator, and i can get my co2 bottle refilled for £8, so its not worth it at the moment.
Old 16th January 2010, 09:57 AM
GraemeWebb's Avatar
I get my CO2 from a Wine merchant in Coventry for about £14. Just off to get some actually, and some wire. run out at the same time. I will get the wire (0.8mm) from Halfords if theve got stock for a change.
Old 16th January 2010, 10:10 AM
Davey's Avatar
Davey Davey is offline
I have three small (3 foot) cylinders which I get refilled with CO2 at my local welding supplier. I think its about £18 a refill but not sure as it lasts me about a year per cylinder.
D.
Old 16th January 2010, 05:25 PM
GraemeWebb's Avatar
Welll the gas as gone up to £18 and despite me reserving the wire on the web site (it showed that there was stock) Halfords let me down again. They will get some in on Wednesday.
Old 16th January 2010, 08:44 PM
ACE HIGH ACE HIGH is offline
Try your local fire extinguisher people.Over her they sold me a retested Co2 cylinder with the correct fittings about $35 another $15 to fill it ,then only about 15 dollars a fill for 10 years for another retest,probably a bit dearer these days,often these bottles can be purchased out of date for free or $5/10.
If you use MIG I believe that CO2 is the best way to go,a bit more welding spatter ,slightly stronger and a lot cheaper than BOC or anyone else.
And consider Oxy/propane(LPG)and straight propane for heating,instead of Oxy/Acetelene.David
Old 16th January 2010, 10:15 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
hi, i have several pub style bottles the best one is ali about 6" dia 3ft tall i get it filled at a local fire extinguisher engineering company they pump it in for £1 a kilo so costs £6.50 a fill
you could prob get one from your local and do a swap return thing if you have a friendly landlord
Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 16th January 2010, 10:28 PM
Luke2842's Avatar
Luke2842 Luke2842 is offline
I managed to get mine from Calor Gas, its straight Co2 and it was only £15 for a 3ft one and no deposit. Not too sure why there wasn't a deposit but who am i to quibble?!?
Luke
Old 17th January 2010, 08:28 AM
Ryan Ryan is offline
I did the same as luke, went to see the local calor gas man. £15 for a 3ft bottle. No deposit requiried. When it runs out just return the bottle and swop it along with another £15 for a fresh one.
