Old 15th January 2010, 04:31 PM
AndyLockwood AndyLockwood is offline
Default Co2 cylinder
Does anyone in the devon area have a Co2 cylinder i can borrow/buy/loan to save on disposable bottles or overpriced BOC charges.
Andy
Old 15th January 2010, 05:10 PM
Tatey's Avatar
Tatey Tatey is offline
If you have no luck here try http://www.mig-welding.co.uk/forum/index.php, as thats where i managed to get mine for free . If that fails, talk to your local pubs and see if you can blag one from them.
Old 15th January 2010, 05:21 PM
ok ill check it out thanx.. local pubs just changed hands so dont think ill have much joy there
Old 15th January 2010, 05:30 PM
davidimurray's Avatar
If that fails try giving Andy Kearsey a ring at Target Tools and Equipment. Andy is based in Gloucester but has a few distributors around the UK.He does a deal where you hire a bottle that costs around £50 for 3 years, there is a refundable deposit of around £30 and then around £25 per refill. His number is 01452 739005 or email targetgas@blueyonder.co.uk. Can supply Argon/Co2 or straight argon as I get for Tig welding.
Old 15th January 2010, 05:40 PM
That's commonly known as theaft, the bottles usualy still belong to the brewery or the gas supplier directly. Just like Bear Barrels that you can get done fore if found with them.
I use Clarke extra Fill, they last much longer and only cost a quid more than normal bottles.
Old 15th January 2010, 05:44 PM
Tatey's Avatar
You learn something knew everyday .
Old 15th January 2010, 06:00 PM
I know this relates to the kegs, but brewerys are not thick when cylinders of C02 go missing..
http://www.kegwatch.co.uk/press.htm
Old 15th January 2010, 06:51 PM
got mine from energas. £35 for a 6foot tall argon c02 mix gas no rental charge just take it back when your done with it.
think it was £50 for pure argon. they have depots dotted around from the Birmingham upwards. the bottles are so big that they will last a couple of car builds so its worth the drive.
Old 15th January 2010, 06:54 PM
are energas a local or national company sounds like a good deal
Andy
Old 15th January 2010, 07:03 PM
http://www.energas.co.uk/location.asp
