Old 21st August 2010, 12:39 PM
nnrouty nnrouty is offline
Why though? You can sell them for more than the cost of the items you need.
If your a design engineer then build your own uprights for a challenge
Just on the subject of redesigning uprights..... you guys mights be intrested to know that i've designed my own rear upright which use the same wish bones and sierra parts. Waiting for them to be tested then will mabe make a few pairs if anyone is interested?
Also hope to develop the rear upright so that the hub carrier/bearings are part of the uprights.
Building 1800 Zetec Roadster
Old 21st August 2010, 12:55 PM
Originally Posted by nnrouty View Post
Just not very clued up on suspension goenometry.
And I made the comment because you've received advice that the consensus of which is that it is better to use Sierra uprights, and yet you seem happy to go ahead with the Cortina units, I formed the impression that you felt your engineering background trumped that advice, if I was mistaken, I apologise.
Old 21st August 2010, 01:10 PM
Sorry not trying to cause arguments. I'm always willing to lean new things
Old 22nd August 2010, 01:35 PM
Hi all
Last night i spent a few hours on AutoCAD and have finalised that you can use the cortina front upright providing you extend the upper front wishbones by 54mm and remove the 8'degree angle for the camber adjuster.
I have DWG drawings available that show zero bump steer using this setup.
No other changes needed.
Old 22nd August 2010, 03:17 PM
So the steering arm is located in exactly the same place in relation to the lower pivot?
Old 22nd August 2010, 05:42 PM
The relation between the track rod end and the maxi ball joint is not the same as the relation between the joint in the steering rack and the wishbone mount. But after drawing the suspension with the sock closed and partly closed there are no changes in distance from the track rod ends to the chassis.
Old 22nd August 2010, 06:04 PM
Attached pdf
Old 22nd August 2010, 06:25 PM
davidimurray's Avatar
What affect does the wishbone lenght change and geometry change have on the roll centre?
Old 22nd August 2010, 10:20 PM
See attached
Old 22nd August 2010, 10:23 PM
Thanks for that drawing - any idea how it compares with the sierra based setup?
