Old 20th August 2010, 05:11 PM
nnrouty nnrouty is offline
Default Front Uprights
Hi everyone
Little while ago i got some cortina uprights given to me from my uncle which he had spare from his locost he built a few years ago.
I have now got to wondering weather the front suspension based on the Ron Champion book (which my uncle built) is the same as the Haynes roadster which i am building?
Soooo, can anyone tell me if I can use the Cortina Uprights on the Haynes roadster?
Old 20th August 2010, 06:00 PM
No it's different. Sell the cortina ones, buy some sierra ones and you should be quids in
Old 20th August 2010, 09:08 PM
Found this:
http://www.haynes.co.uk/forums/showt...rtina+uprights
Will this work?
Building 1800 Zetec Roadster
Old 20th August 2010, 11:19 PM
allterrain's Avatar
allterrain allterrain is offline
Check out this thread as well.http://www.haynes.co.uk/forums/showthread.php?t=3492 Cheers Brendan
Old 20th August 2010, 11:51 PM
Ok now I’m confused! These links contradict each other?
Old 21st August 2010, 10:55 AM
The simple answer is yes you can use cortina up rights,how ever you will need to change the design of the front wishbones. You will need to have a full understanding of steering geomentry ie camber,caster,toe,bump steer,ackerman,king pin inclanation etc to make sure your car is safe to drive. You have to weigh up wether it's worth reinventing the wheel when you can pick up the book know the design works and build it. Your time and money your choice.
Old 21st August 2010, 11:08 AM
I think i will take a look.
Im a Design Engineer by trade so should be able to work something out.
Old 21st August 2010, 11:28 AM
Why though? You can sell them for more than the cost of the items you need.
If your a design engineer then build your own uprights for a challenge
Old 21st August 2010, 11:30 AM
Well, there you go, no problem. Surprised you asked, quite honestly.
Old 21st August 2010, 01:32 PM
I asked because i usualy deal with structural engineering.
Just not very clued up on suspension goenometry.
