Old 20th September 2010, 02:55 PM
Oily's Avatar
Oily Oily is offline
Originally Posted by 3GE Components View Post
Personally, I'd go up a size to 1-1/8" for the main tubes etc etc.
Kind regards
John
Thanks John
Work is for people who don't know how to fish!
Old 20th September 2010, 03:19 PM
davidimurray's Avatar
Originally Posted by Oily View Post
Forgot to ask would you do like for like,i.e 1" tube instead of 1" box?
You should calculate the second moment of areas and work out the equivalent stiffness of the round tube relative to the square tube.
Old 20th September 2010, 07:52 PM
Tilly819 Tilly819 is offline
hi all heres my 2 pence worth
in comparision to a 16swg box chassis such as mine
to make a tubeular chassis it would be worth making it out of 1 1/4in tube which would enable you to drop the guage to 18swg and maintain the same stiffness and also drop the weight from about 52kg to 40kg
however as soon as you drill a hole in tube to say rivit on the floor it will reduce its strength more so then with box
and you have to be alot more accurate in doing so sich you have a curve rarther than a flat
hope this helps
calculations were very quick and very aproximate
tilly
Old 20th September 2010, 09:04 PM
Oily's Avatar
Fancy doing this for me David as my calculus is a little rusty
If I were to use 1" 1/8 tubing I'm guessing I'd have to recalculate all the measurements of each piece?
