Old 20th September 2010, 12:25 AM
Oily's Avatar
Oily Oily is offline
Default Tubular chassis?
Just throwing this idea out there,how hard would/could it be? Is there any part of the chassis that couldn't use tube,like the wishbone mounting points etc?
(Tried searching but came back blank on the forum.)
Work is for people who don't know how to fish!
Old 20th September 2010, 06:34 AM
snapper snapper is offline
Next time you are at a show, have a good look at the MNR chassis.
If you wanted to build your own round tube chassis, the MNR one is the standard you should be looking to emulate
Old 20th September 2010, 07:10 AM
Roadrunner racing do a round tube chassis also with their SR2
http://www.roadrunnerracing.net/rr-g...d-gallery.html
Old 20th September 2010, 07:53 AM
hi. It's been a while since i have been on here but on my chassi i used tube on the top of the tunnal to make the edgees nice and soft and i was then going to make a one peace grp panal that drops over the top so it dosnt have any seems and i also have plans to make another chassi in 316 polishd stainless steel tube i just think it would look so cool
Old 20th September 2010, 09:21 AM
Oily's Avatar
Thanks for the replies.Just had a look at the above,very nice
Just flicking through the book and trying to see where you would struggle in any areas if a tube chassis was the order of the day.
Old 20th September 2010, 09:33 AM
I dont think you would have any probs just the fact that you would have to fishmouth most tubes where they meetand it would consume a lot of time.Unless you have access to a lathe which would make it easier.
Old 20th September 2010, 09:55 AM
3GE Components's Avatar
There's no reason at all why you can't use round tubes, square is easier to work with for a home builder, which is why it's more common.
Cutting round tube can be done with a tube notcher, http://cgi.ebay.co.uk/WNS-Pipe-Tube-...item3360cc8870 , the "hard" part is keeping the fish mouths parrallel to each other.
Brackets for suspension etc will have to made, as they are not a stock item anywhere, this is something we could do for you if you wished.
Putting panels on is a bit trickier, as you have a smaller contact area for the rivet, so accuracy is paramount.
On the plus side, round tube chassis's look far better
Kind regards
John
Old 20th September 2010, 11:49 AM
Oily's Avatar
Will bear this mind John if I go down this route I'm still weighing up which way to go
I do have access to a machine shop so that's one less thing to worry about
Old 20th September 2010, 12:52 PM
Oily's Avatar
Forgot to ask would you do like for like,i.e 1" tube instead of 1" box?
Old 20th September 2010, 01:32 PM
Personally, I'd go up a size to 1-1/8" for the main tubes etc etc.
Kind regards
John
