Well said Ronnie a milling machine is not what I would call a "fabricators" tool it's a "machinists" tool.
I worked in a narrow boat yard and all we had to make 70ft steel hulls with was an oxy set, angle grinder and a mig. Besides which the angles don't NEED to be spot on as it's a welded assembly.......secret tips you won't learn in any college will result in the correct dimensions Quote:
Ok Ronnie thats fair comment.
Other 5 paragraphs deleted.
Website http://www.talonmotorfabrication.co.uk/ Direct email phil@talonmotorfabrication.co.uk talonmotorfabrication@gmail.com Mobile office hours 07514098334 |
TIG with a foot pedal is my option in that situation, technically pulse is a machine function that raises and then lowers the current on a set time base to preset maximum and minimum current set points. the beauty of the tig with the foot control is it allows you to keep an arc going wile you reposition your torch and or yourself to continue your weld. however if you do not have these facilities at your disposal you current method of what i would refur to as "tacking" or if you can do a small run "stitching" may well be you only option. hope this helps tilly Edit: PS if this is the case, it might be worth upping your current to help get abit more penetration Welding is like sex, its all about taking your time and getting good penetration ![]() Last edited by Tilly819 : 13th February 2011 at 10:36 PM. |
pulse migs are a inverter based mig welders that fluctuate the supplyed power and feed eletronicly to suit the job, mainly for spasific applications and materials like thick to thin programs or in production lines etc. units come from small to massive and sometimes called synergic and weld allys real nice
programs and settings (what material,wire,gas,transfer style and thickness ) are set and the eletronics know how the arc is working and ajusts as it goes i have demoed a few units and some have pritty cool funtions like when you tap the trigger the settings change so you can weld one continous bead but change position as you go without changing your speed or adding weve like welding all the way around a window frame without stoping. small basic units are now comon place in modern bodyshops with the need to migbraze boron steel bodywork on newer cars even used a migatronic that had two torches one ally one migbraze (or steel) just grab the one you want and tap the trigger and off you go. pulse tigs on the other hand are getting very comon now and pulse the out put hi lo hi lo to minimise heat input and keep thing neater and quicker |
| Thread Tools | |
| Display Modes | |
