Old 18th February 2011, 08:12 PM
ChrisJ ChrisJ is offline
Default My Builed Thread
The time has come!!!!! and the smile on my face is huge!!!
Received my stage 1 chassis kit from Andy yesterday so today i got busy starting to put it all together, thought i'd pop up a build thread to track my progress, throw some ideas about etc.
I'm building the chassis at my unit as there's more space, it's warm, lightings good and most importantly i've already got a solid work table to use.
The table i'm using is a roller blind table ( i manufacture/install window blinds) and the table was setup and bolted down perfectly level, so it's a good base.
I've attached a sheet of 15mm mdf and screwed it down tight so this will be the base.
Build area
After unwrapping Andy's superb chassis pack i started to lay it out and get an idea of where it all goes, pretty quickly layed it all out and began to mark up the base board.
Laying and marking up
Eventually had it all marked and most parts blocked in, left it this evening with just two bars needing placing in.
Stage 1 under way,
Total spend so far £95
Old 18th February 2011, 08:13 PM
All going well so far, just need to check all the measurements and placings a few more times and i can begin tacking it together.
A huge smile on my face now i'm underway.
Stage 1 under way,
Old 18th February 2011, 08:19 PM
Davey's Avatar
Davey Davey is offline
Looking good bud, just remember to remove all those rolls of fabric before you pick up the welding torch . I look forward to following your build.
D.
Old 18th February 2011, 08:36 PM
Blinding progress...
Old 18th February 2011, 08:45 PM
Very Good Should have expected a few of these.
Stage 1 under way,
Old 18th February 2011, 08:58 PM
Looking great Chris ,
Thanks for your kind words of the kit
You,ll soon be sat in the chassis with the "Air Steering Wheel" .....we,ve all done it .
I look forward to seeing more updates on your build progress.
Old 18th February 2011, 08:44 PM
Thanks Davey,
I've got boards to cover the sides plus it's all fire retardant anyway
Chris
Stage 1 under way,
