Old 29th August 2011, 08:11 PM
MarkB MarkB is offline
Originally Posted by baz-r View Post
dam i was hoping with a reply i got one you can use
lol
Use a hole saw, drill a pilot hole the same size as that on the hole saw then bingo......or if you have them a rotobroach is a really good way if you must have them on the roll bar as I would sooner see them fitted to the chassis.
Old 29th August 2011, 08:17 PM
lol
Mine are either too big or too small, besides the two way postage of one would probably be almost as expensive as an ebay El-Cheapo
Old 29th August 2011, 08:51 PM
where would it be mounted on the chassis to get the right belt heights for iva?
Old 30th August 2011, 08:54 AM
The top rail that runs along the top of the seat bulkhead is plenty high enough
Old 30th August 2011, 01:50 PM
Also use some form of lubricant as you drill it( WD40 very good and cheap).
Old 30th August 2011, 08:13 PM
Step drills are good too, i have one thats steps from 4mm to 28mm in 2mm increments and fits in a small chuck no problems
Admitedly they are designed for lighter work but i have used them on heavier stuff plenty of times with no problems as long as you use an appropriate drill speed
Old 30th August 2011, 09:27 PM
Luke2842's Avatar
Luke2842 Luke2842 is offline
That's where I've put mine and works well with the eye harness mounts
Old 31st August 2011, 03:01 PM
brainbug007's Avatar
can anyone post some pics of how they've done this? I'm having a hard time visualising how you guys have done this compared to the suggested method in the book?
Old 1st September 2011, 02:32 PM
No one able to post a pic?
Old 1st September 2011, 02:52 PM
