Old 28th August 2011, 03:52 PM
Default top belt mounts in cross tube?
anyone know if there are any reasons why a hole cant be drilled all the way through in the cross tube on the roll bar and the threaded tubes welded into them doing away with thoes flat plates?
i think it would be neater and have less edges.
Old 28th August 2011, 04:14 PM
Hi Baz
I think that is the way most folk prefer to do them
That is certainly the way I am doing mine & I believe Ash done the same
Truth be known, I expect most IVA inspectors would prefer to see them done that way.
Old 28th August 2011, 04:58 PM
jerkins's Avatar
jerkins jerkins is offline
This is what I did (this drawing was for the benefit of Mr SVA).
Sorry it's a bit small - this forum wouldn't allow me to put anything bigger up...
Old 28th August 2011, 08:58 PM
The threaded tube must be welded on both sides of the bar to pass iva.
I did mine as per the book but cut the cross bar out as I felt it was too thin, I bought some new bush tubes off Ronnie and will put them through the bar when the time comes.
Old 28th August 2011, 10:24 PM
gus's Avatar
gus gus is offline
That's how mine were done.
Gus
Old 29th August 2011, 05:13 PM
Mine too .
