Old 7th December 2011, 02:30 PM
Dont book and mot your car,there is no need for three years as it is a new build and they will want you to test it very year if you do.
Old 7th December 2011, 02:59 PM
brainbug007's Avatar
I wasn't planning on having a proper mot, just a pretend one to have them check it over for anything obvious that would cause an iva failure.
Old 7th December 2011, 04:10 PM
MikeB MikeB is offline
Any chance of getting the map for the zx6r carbs on a 1.8 cvh?
Megajolt is my next step.
Mines running with just edis and a coil pack. Coudl that be the reason the manifold was getting very hot just ticking over for a minute?
What mods did you make to the carb jets?
Old 7th December 2011, 04:57 PM
sure I'll try and post it or email it on to you when I get home.
Not sure about your manifold getting hot, never really checked mine as I didn't let it run for very long like that or put my hand near it..
I was advised to leave the jets as is until post iva to help get through the emmissions & just not rev it too hard as it'll be running lean. I'm planning on trying some 175 & 185 jets after iva though
Old 7th December 2011, 06:58 PM
Here's what Dave sent. He said he got them from DaddyA and he was using mymap_3_after_v3.2.1_upgrade. The other map mymap_4_11_July less top-end bins he thought the rev bin range was all wrong as if you are idling at 850 to 900 rpm any bins below that will never be used. It won't let me upload the files directly here but they're basically just text files so copy paste into notepad and save as the filename (the .mjlj at the end is the important bit for the MJ software to recognise it)
mymap_3_after V3.2.1 upgrade.mjlj (don't copy/paste the ======)
cylinders=4
mapBins=0,10,20,30,40,50,60,70,80,90
rpmBins=10,16,22,28,34,40,47,53,59,65
advance0=12,24,29,32,34,35,35,35,35,35
advance1=12,23,29,31,34,34,35,35,35,35
advance2=12,23,29,31,34,34,34,35,35,35
advance3=12,22,28,30,33,33,34,34,34,34
advance4=11,22,27,29,32,33,33,34,34,34
advance5=11,19,27,29,30,31,32,33,33,33
advance6=11,19,25,28,29,29,31,31,31,31
advance7=10,17,22,26,27,27,29,29,29,29
advance8=10,17,20,24,25,25,27,27,27,27
advance9=10,16,19,21,23,24,25,25,26,26
userOutType0=1
userOutMode0=0
userOutValue0=48
userOutType1=1
userOutMode1=0
userOutValue1=54
userOutType2=1
userOutMode2=0
userOutValue2=56
userOutType3=1
userOutMode3=0
userOutValue3=77
shiftLight=65
revLimit=70
mymap_4_11_July less top-end bins.mjlj
cylinders=4
rpmBins=5,6,9,12,16,22,28,34,40,47
advance0=5,20,14,14,24,29,35,39,41,42
advance1=14,14,14,14,23,29,34,39,40,42
advance2=14,14,14,14,23,29,34,39,40,41
advance3=14,14,14,14,22,28,33,38,39,41
advance4=13,13,13,13,22,27,32,37,39,40
advance5=13,13,13,13,20,27,32,35,37,39
advance6=13,13,13,13,19,25,31,34,35,38
advance7=12,12,12,12,17,23,28,32,33,36
advance8=12,12,12,12,17,21,26,29,31,34
advance9=12,12,12,12,16,20,24,28,30,32
userOutType0=1
userOutMode0=0
userOutValue0=48
userOutType1=1
userOutMode1=0
userOutValue1=54
userOutType2=1
userOutMode2=0
userOutValue2=56
userOutType3=1
userOutMode3=0
userOutValue3=77
shiftLight=65
revLimit=70
any problems let me know and I can email the files on if needs be.
Old 8th December 2011, 11:39 AM
cheers I haven't got my megajolt yet but it won't be far off.
