I've finally got my megajolt all connected up and running with the basic map that came pre-loaded from trigger wheels. Not really understanding the principles used very well I'm after a guide of sorts to start learning how it works so I can make tweaks to it without breaking it or my engine. For example I'd like to know how to compare two different maps and understand them well enough to decide which is better for my setup if that makes sense? At the very least I need to know how to tweak it at IVA incase I'm over on my emmisions.
From what I understand so far you "retard" the ignition so it sparks after tdc making it more inefficent which brings down your emmissions? And to do this you increase the advance value in the given cell? Also it's bad to have it sparking before tdc as messes up the pistons by forcing them down when they should still be traveling up the cylinder? To bring the spark closer to tdc and increase the power, do you increase or decrease the advace? How do you work out the advace value of tdc that you should not go above/below (see point above) which would cause it sparking btdc? In reverse, how do you work out the maximum value you shouldn't go beyond for atdc? Also the advance value seems to change depending on rpm/throttle, why is this? Sorry for all the newbie questions but any help would be greatly appreciated! |
| Thread Tools | |
| Display Modes | |
