Old 12th August 2012, 10:29 PM
Originally Posted by robo View Post
I found a neat way of mounting exhausts on kit cars using the mini rubber mount from the middle of the system, I used them as below on the underfloor system on my old cobra but they would lend themselves to the side of the roadster like in skovs case.
Take the exhaust clamp and drill an 8mm hole in the middle
Thin down a 5/16 unf nut an push it into the clamp. Its not metric children.
Then screw the clamp onto the stud and bingo.
You will only need two rivnuts in the vertical tubes on the side of the roadster and no brackets are needed. The exhaust will hide the whole thing. Just trim off the excess thread.
Now thats a clever idea!!!!!! Thats one for the bank.
Old 13th August 2012, 08:07 AM
snapper snapper is offline
The exhaust tube past the can will also get very hot
If your worried about your kids legs ( and I would be, very) make up a guard
