Old 8th August 2012, 09:43 PM
Default Exhaust Mounting?
Hi all,
I got a motorcycle end can today, and I'm trying to figure out how to attach it to the chassis.
Does anyone have any ideas, or pics of how they done theirs?
Ta,
Old 8th August 2012, 10:09 PM
one moment whilst i look...
Old 8th August 2012, 10:12 PM
A exhaust bobbin is mounted centraly in the valley of the pressed part of the clamp and the protruding thread removed.
The bottom of the bobbin fits into the flat strip that attaches to the chsssis.
Solid enough.
Old 10th August 2012, 03:03 PM
jps jps is offline
Ah ha. I was about to start a very similar thread.
How is that flat strip attached? Does something need welding into the chassis rails at an early stage - or is it another rivnut job (seems like kit cars are mainly made of rivnuts!!)
That exhaust looks very nice by the way!
Old 10th August 2012, 10:14 PM
mgglep's Avatar
mgglep mgglep is offline
Yeah that's all I did I used an exhaust bobbin from halfords about £2 then used an exhaust clamp and a bit of flat
Have a look at this if you like
http://m.flickr.com/#/photos/67605695@N04/7113738733/
My Build pics
Old 10th August 2012, 10:41 PM
the flat strip is bolted to the floot, you can see the bolts.
Old 11th August 2012, 10:20 AM
Thanks guys, I think that helps!
The exit on my can is quite short, and comes out at an angle which would make it difficult to get a clamp around it like you've both done, so I guess I'll have to come up with another plan.
In terms of position, pretty much every 7 I've seen has the can in roughly this position:
Would it look completely stupid if I positioned it futher forward like this:
If I put it in the second place the kids are less likely to stand on it / burn themselves on it getting in and out, plus it saves me a few feet of exhaust tube!
Just not sure if people will point and laugh if it's not in the more traditional location
Old 11th August 2012, 12:24 PM
mgglep's Avatar
I remember reading somewhere about needing so much exhaust tubing from the engine for maximum exhaust efficiency can't remember what the length is though
My Build pics
Old 11th August 2012, 08:56 PM
I found a neat way of mounting exhausts on kit cars using the mini rubber mount from the middle of the system, I used them as below on the underfloor system on my old cobra but they would lend themselves to the side of the roadster like in skovs case.
Take the exhaust clamp and drill an 8mm hole in the middle
Thin down a 5/16 unf nut an push it into the clamp. Its not metric children.
Then screw the clamp onto the stud and bingo.
You will only need two rivnuts in the vertical tubes on the side of the roadster and no brackets are needed. The exhaust will hide the whole thing. Just trim off the excess thread.
Old 12th August 2012, 09:30 PM
bike cans also come with a strap normally. the endcan on mine had it as part of the can itself being oem. so i just made a bracket to fit that with a small rubber mounting tapped the frame so the rubber mounting is on the frame all the time and the bracket just slips on and bolts up.
