Old 17th November 2015, 11:46 PM
norton norton is offline
It's fiddly, boring and time consuming. Poo. I'll sulk for s few days then get on with.
Old 18th November 2015, 10:46 AM
Rosco Rosco is offline
looks bloody mint pal!
My Build Thread
Old 18th November 2015, 07:07 PM
Thanks Rosco, it'd look even better if I had one of those superb looking battery trays you've made
Does anyone have a spare mx5 throttle cable at all?
Old 18th November 2015, 09:46 PM
Lol, send me a drawing and i will see what i can do!
My Build Thread
Old 18th November 2015, 10:07 PM
Well, exactly the same as yours assuming you have a standard floor pan? I was very impressed by it, much better than those welded ally jobbies all over eBay!
On the progress front I have now made the two front brake pipes and mounted a tee by the mc to accommodate a brake light switch. I'll get to work on the long front to rear pipe tomorrow.
Old 19th November 2015, 05:15 AM
ok i will drop you a u2u, as for your brake light switch, a few people have said it takes a bit of pressure on the pedal to get the lights on and end up swapping to an electrical switch on the pedal, just a thought
My Build Thread
Old 19th November 2015, 11:11 AM
Ill be adding a manual switch at some point for this reason.
Old 21st November 2015, 09:34 PM
SteveH1 SteveH1 is offline
Hi Norton
did u put in grp1 and 2 at the rear
and did d 13 fit ok
the saturn plans say it should be 304 but it seems to be too short
but I'm not sure i have grp1 and 2 correct i have grp 1 level with rs14 is that correct
thanks
Old 21st November 2015, 10:08 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Originally Posted by SteveH1 View Post
Hi Norton
and did d 13 fit ok
thanks
If I remember correctly grp1 and 2 should have a 5° angle upwards from rs14
Old 22nd November 2015, 09:40 PM
The diagonal that connects to the rear most rail was longer than the plans. I can't remember my final measurement. I assembled all the other rails then cut the diagonal to suit.
