Old 4th January 2017, 05:59 PM
norton norton is offline
You're s star thank you! I'll hopefully be able to start it this week now.
Thanks again!
Old 10th January 2017, 05:50 PM
Exhaust.
I had welded the 90/rolled tip together by here and tacked together the cat. I'll crack on with the pipe between the cat and manifold this weekend. I need to rig up an argon back purge then I'll weld the rest. Tig welding stainless wasn't as straightforward as I presumed...
And some white vinyl wrap!
Old 10th January 2017, 06:08 PM
SteveH1 SteveH1 is offline
Lookin good fair play.
Where did you get the exhaust parts they look nice
Old 10th January 2017, 06:12 PM
Thank you, they're from several different vendors across eBay and the net. Wherever was cheapest! Profusion exhausts had the bends and cat which was much cheaper than most. I wanted to future proof the exhaust as I will turbo charge the engine after iva so went with an admittedly excessive 3" diameter setup but it certainly looks good!
Old 11th January 2017, 07:26 AM
garyout garyout is offline
Looking good mate how was the vinyl to put on ?
Gary
Old 11th January 2017, 07:51 AM
It wasn't too bad once I'd gotten the hang of it. Definitely a two person job. One to hold it tight once started and the other to squeegee it on. It looks good though.
Old 11th January 2017, 08:44 AM
yea I agree top job I get the arse hanging wall paper
Gary
Old 11th January 2017, 12:24 PM
Originally Posted by norton View Post
Exhaust.
Oooo looking good, like that exhaust with those sexy tires.
Old 12th January 2017, 11:43 AM
Ianr Ianr is offline
I did similar with my exhaust system but felt I would have an issue with the edges of the silencer facing front and rear at IVA. To get round it I got an old saucepan lid (don't tell the management) and cut a hole for the exhaust pipe, fitted a treat and looked good as well
Old 12th January 2017, 12:54 PM
That's my kind of solution! Ace!
