#31
Aargh, if I knew they were 55 watts each I would had known what the current would be, i feel like a bit of an idiot now
, I'll order the wire tomorrow and hopefully gt building this week then. Thanks hugely , I wolldnt be anywhere without these forums.![]()
my build pics |
#32
Worth trying your local caravan dealer as they usually stock 7 core and 10 core cable.
#33
Think These are about right from memory..
Main 55W Dipped 55W Side 5W Tail 5W Fog 21W Brake 21W Indic 5W Rev 21W Dash 5w per ilumination lamp approx. HORN - QUITE A LOT! Blower - QUTE A LOT TOO! Fan - SHED LOADS! Engine - very little Starter - WOOOOo!!!! ![]() TT
#34
my nas type indicators come with 21watt bulbs although i think it can vary depending on style of the lights.
#35
Sent you a PM. Can send you the diagrams that i sell with my kit if you wish....
#36
Your right indicators should be 21W not 5W
#37
Morning guys, approximately how much 10 core cable did you guys need to do your loom please?
Cheers Jas
http://www.flickr.com/photos/3326151...7611049241239/ |
#38
i got 5m i think from memory. will have a look at the receipt this afternoon to check
#39
Cheers Ash,
Im currently thinking, run 10 core to the rear, and 2 7 cores to the front, one for each corner! ![]()
#40
quick note dont forget to factor in lower voltages as this will push the amps up a bit
55w/14v=3.92A running/charging 55w/12v=4.58A stoped/ok 55w/11.5v=4.78A flat! so dont forget to uprate the cable above the duty needed! or the smoke will leak out of your cables when i was at collage studing auotmtive engineering/design/eletronics the rule of thumb was to work all of this and factor it into everything and i thort it was a compleate waste of time the idea is fine for working out fuse sizes but i would be factoring in 15-20% above duty for cable sizes stuf like bulbs,fuel pumps etc may well be uprated in the future |
| Thread Tools | |
| Display Modes | |
