Hi all,
Ive recently been contemplating on the thought of making my own loom from scratch, just using the existing connectors from the original sierra loom, i kno i could buy one or use my existing sierra loom, but i wondered what is involved in making my own. I have a 1.8 carb cvh, and wondered what are the minimum connections to it are actually necessary to pass the iva, ie, do i need most of the sensors on the engine. Also i plan on using the sierra Haynes diagrams to build it, but does anyone have any suggestions as to if there are more useful diagrams available to build my own loom. Also i remember reading on here somewhere that someone else had made their own loom? should i use my existing fusebox as well? Thanks ![]()
my build pics |
just one other thing, i know this may sound stupid, but im on a card cvh, but the digram has a hybrid ignition module, and electirc choke, does my cvh even have these? if so, do i need them?
Thanks again!!
my build pics |
i made my own loom one 10 core trailer cable to the front one to the rear job done. the only sierra bit i used was the plugs for the sierra steering column.
there are some good wiring diagrams on westfield world that will help you split the wiring down into manageable tasks |
1) Haynes diagrams are pants. The official ford diagrams are the best.
2) the Engine loom is a seperate part to the body loom. Keep that in one bit. Don't get rid of any sensors. All it whould need is a +12V, and ignition live to get it running. 3) Yes you need the Module, unelss yout want to build your own ingnition system. 4) If your building your own loom then there's no point in useing the sierra fuse box. TT
Personaly I would bin the Sierra fusebox .........A hulking great lump, full of fuses & relays that you'll never need
Besides the engine loom.....The rest of the wiring is very basic & will prove to be quite simple if you break it into smaller individual circuits. As said, if you are using the CVH engine as originally fitted to the car, try to keep the engine loom in one piece & don't bin any sensors. Multi-core wire will be your best friend if you want to keep things nice & tidy ![]()
I am not a complete idiot...........Some of the parts are missing !! Ronnie ![]() www.roadster-builders.co.uk |
I used the wiring and fusebox out of my 1.8 CVH. I'm using a Megajolt ignition, so I had to make my own engine loom anyway. Stripping down, shortening and re-taping the Sierra wiring took around 6 hours shop time and around 2 hours reading the haynes manual and marking it up properly. I'm also using the Sierra stalks on the steering column and the instruments, so it made more sense.
Obviously the advantage of this is I now have a complete wiring loom, relays and fuse box, at zero cost. But the whole thing was very easy to do. |
I did a similar thing as deezee, stripped the standard cvh loom of all the excess wiring (shed loads) and binned the ignition module and all the sensors in exchange for megajolt
To be honest it took me a lttle while to get it sorted as prevously i had zero automotive wiring knowledge, but it really isnt that difficult once you get your head around the wiring diagrams. If you have the donor loom i would use it and just strip out the uneeded wires carefully The result is a loom that cost me nothing and i aquired some new skills at the same time |
does anyone have any pics of a stripped cvh loom?
cheers matt |
That's quite insightful... I've stripped my loom but didn't realise the engine loom could be detached. I'm sure it's obvious when the loom is stretched out, but what does the connection point for the engine loom look like?
Depends on the modle year.
Pre 90 cars have 3 plugs on the inside of the car. 3,6,9 pin. Post 90 cars have 3 plugs behind the batery ( two oval and one square ) All Sierras should have these plugs. If you look at, http://www.claytune.org.uk/ Weblinks, Other resources, "Loom plugs ( granada to sierra)". That gives most of the info on the plugs although it's intended for a slightly different audience. TT
| Thread Tools | |
| Display Modes | |
