Old 29th April 2013, 05:08 PM
I should be alright as long as it doesn't shoot a scorching hot bundle of wire at the IVA man during the test
I don't think that's a fail anyway so you should be fine!
Old 29th April 2013, 06:40 PM
I'm not so sure... I suspect maiming the tester is covered by point 1 in the General Construction section:
1. All aspects of the design and construction of the vehicle must be such that no Immediate danger is caused or likely to be caused to any person in the vehicle or to other road users
Old 29th April 2013, 06:44 PM
But is it an immediate danger?
How did you get on with your brake pipes up front? I see another member was failed for not having them clipped to the wishbones. Is that our worry with them failing?
Old 29th April 2013, 09:12 PM
It is if it's flying towards your face!
The strange thing is I'm sure I've seen people fail FOR clipping them to the wishbones!
I think mine should be ok, but I'd better check them again next time my wings are back on the car. I'll add that to my "to do" list...
Old 29th April 2013, 10:06 PM
I guess the point is they can't be chaffed or damaged by other parts of the car. If you just zip tie them to the wishbones then it's as bad as having them rubbing anyway. But it's all down to tester interpretation I suppose. Caterham's don't appear to clip them so....
I've clipped mine because they came with a metal collar for a support and I might as well use it.
Old 30th April 2013, 09:46 AM
I guess that makes sense if they came with mounting collars.
I think I'll leave mine dangling in the wind and hope for the best (and take some clips and cable ties with me just in case!).
Slight change of subject, I think I promised to put up some more pics of my front wing stays.
Here's a couple of the passenger side.
It's made from 3mmx25mm strip, a bit of scrap 3mm plate, and some round tube from an old bed frame
Old 30th April 2013, 09:49 AM
Excellent. If it rains this weekend I might have a go at making a pair of these.
Old 4th May 2013, 09:17 PM
Not been a great day in the garage today
I thought I only had trim left and was seriously considering sending my IVA application off next week...
Then today I found out that my engine's leaking oil, one of my rear calipers is siezed, and one of my driveshaft boots is leaking. I'm not amused
Old 4th May 2013, 10:38 PM
I've got to find the oil leak on my engine. Not looking forwaed to that job.
Old 4th May 2013, 10:45 PM
I think I've got a spare set of rear callipers in the garage somewhere. You can have them if your cover the postage.
Let me know if you need them and I will pop them in the post
