Old 6th January 2013, 04:01 PM
BenBrooks BenBrooks is offline
Default Painting is the worst thing...
Finally have finished painting the chassis and wishbones, probably the worst experience, i really dont like painting but at least its done now.
Some pics:
remind me to get everything powder coated next time..
Ben
Build photos: http://s1056.photobucket.com/albums/t362/benbrooks1/
Old 6th January 2013, 04:13 PM
Unhappy I hate painting too
It was definitely the lowest point of my build.
A time consuming & thankless task if you are not the kind of person who enjoys painting.
If I had to do another chassis it would certainly go off for powder coating.
At least you have that part of the build over with, now you can get onto the fun bit of final assembly.
Old 6th January 2013, 04:15 PM
yeah, it feels very strange putting my welder, angle grinder and hacksaw away for the last time but brakes and floor next then engine in!
Ben
Old 6th January 2013, 04:31 PM
rpjg1975 rpjg1975 is offline
I feel your pain. Remember the finger cramp well. Hopefully u Didn't miss any.....I remember every time I turned round I spotted a side that I had missed!
Old 6th January 2013, 04:40 PM
You think doing it with a brush is a ball ache you should try spraying one, I think I got more buff coloured etch primer and 2k gloss black over my arms than on the chassis.
I've had some great fun painting chassis one that sticks out in my mind was an Exo super trike chassis that I did a few years ago for Rayvolution cars. Silly bugger here walked in to it 10 mins after the final coat was put on a day before it was due to be at the Stafford show.
Old 6th January 2013, 04:54 PM
You are not wrong there
Wastes an awful lot of paint too.
I used to have access to some electro static spray gear for that kind of job but as ever, costs an absolute fortune for the kit.
Old 6th January 2013, 05:11 PM
that makes me feel better.
i kept thinking as i was doing it this would be so much easier to spray but maybe not. trouble is, the paint kept smearing off when i went over it.
Old 6th January 2013, 05:21 PM
What primer and top coat did you use if it smeared off?
Old 6th January 2013, 05:27 PM
Tatey's Avatar
Tatey Tatey is offline
I found for the chassis the best way to paint it was to use a roller, massively reduced the time to paint it and then you go over the corners with a brush, gives a nice finish as well.
I did two coats of epoxy mastic 121 then light sand and just a two pack polyurethane on top which is the black. it would go on and then as i brushed over it again it would just wipe all the paint off so was a pain in the neck and took a lot of paint to do it
