Old 6th January 2013, 04:25 PM
tkpm tkpm is offline
Default Locating a wire
Hi,
I'm having trouble finding a feed for my dip beam from the light switch, i've a grey for the side lights, the book says brown/black but i can't seem to get any power of this wire no matter what i do with the key or switch position.
Any ideas would be appreciated.
Terry
Old 6th January 2013, 09:56 PM
Probably that wire provides ground for a relay with a permanent live on the other side of the winding.
Old 7th January 2013, 10:38 AM
What year of loom is it.
Old 7th January 2013, 04:39 PM
it's from a 91 H reg LX .
Terry
Old 9th January 2013, 06:09 PM
gaz05 gaz05 is offline
Iirc you won't find a live at the Sierra switch because the switch is used to earth the circuit. The dip relay is with fed with a live from the fuse box and the switch earth the other side of the relay to complete the circuit. I think the side lights are the other way round ie the switch is fed with a live from the fuse box then through the switch to the lights.
Total cost so far
Materials £3,150
Tools £855
Old 9th January 2013, 06:20 PM
That would make sense. thanks
Terry
