Old 23rd February 2013, 03:42 PM
Default Recently rebuilt Ford Pinto engine
I am selling the recently rebuilt standard 2.0 OHC Pinto engine that in my car at present. This was rebuilt for the car's previous owner and has only covered 2,000 miles since a £ 1,000 rebuild which included:
new unleaded valve seats,
seals,
gaskets,
heavy duty oil pump
spray bar
cam followers
bores rehoned
piston rings
big and small ends
big end bolts
crank oil seals, oil filter
high pressure oil pump and sensor
heavy duty sump gasket.
I'm not entirely sure whether the crank was reground or just new bearings fitted.
The engine is in my MK and can be heard running. You are welcome to come down and try it in the car, the performance is good and it runs very smoothly as one would expect for a recently rebuilt engine. I would need a small deposit before removing it from the car.
The engine includes a distributor and would be sold with a exhaust (cast) manifold, but without a flywheel.
Open to offers over £ 250 - It's a perfectly running, very recently rebuilt engine and thats a quarter of the price it cost to rebuild.
I'm currently building up a modified engine and sadly don't have the budget to retain this as a spare engine- it has to go to fund the current build.
