Old 16th April 2013, 06:26 PM
Default Flange adpator
Hi,
I have so much difficulties to get a propshaft for my set up. First, because, even though everybody is complaining about the crisis, nobody looks to want to work: I placed 4 enquiries online (3 in the UK, one in Sweden), and I got only one reply. And when I visit engineering companies here in my neighbourhood, no one wants to shorten my shaft and rebalance it.
The only company who replied is North West Propshafts, and a very nice guy over there (Michael, I definitely recommend them) took care of my problem, but it is not simple.
I am using a MT75 Gearbox, and he made me remove the big rubber joint, then the big steel damper flange, to make sure of what was underneath.
There is a 3-bolt flange directly bolted on the tail shaft of the MT75 where the custom propshaft should be bolted.
But it is not a standard connexion for them, and it raises the price of the propshaft to a level I can not really afford (especially as I have to pay for the shipment to Sweden)
He could make a propshaft with a round differential flange at each end, and it will be much cheaper (and lighter too). Certainly something like that:
But I have to find someone who can machine a special adaptor to make the link between the 3-bolt flange from the MT75 (3 holes 96mm PCD, 16mm Locating Pin, 12.2mm Holes) to a flange like the Sierra differential round flange (109mm Dia, 90mm PCD, 56mm Male register)
Could anyone of you who has a lathe easily do that, and how much would you charge? If you are interested in doing the job, you can reply here or send a PM please.
Thank you very much.
Old 16th April 2013, 07:03 PM
Try Comercial Propshafts of Team Valley Trading Estate Gateshead,Tyne and Wear,England. Stan is the guy to talk to.
Old 16th April 2013, 07:13 PM
Just wait till I look at the transit gearbox which has an mt75, I have one in the shed which may have the 4 bolt flange. It may be the same as the one below.
http://www.roadster-builders.co.uk/f...9&p=2017#p2017
Old 16th April 2013, 09:22 PM
Mk5 Transit MT75 gearboxes are round with four bolt holes and should be a direct fit for that box, later mk6 MT75 are fitted with 3 pin mounts same as that one.
Old 16th April 2013, 09:35 PM
If this is also drive link automotive I used them. Fantastic service. Shortened and balanced same day and also painted!
Old 17th April 2013, 06:53 AM
Thank you for the replies and the tips.
It is rather a good news that this Transit flange exists, it would solve the problem straightly guys, you just made my day!
So Bob, I can't wait to know if you have one. That would be so great! If you do have one, please send me a PM for price and post to Sweden.
Thanks you very much.
Old 17th April 2013, 09:08 AM
jiwillia jiwillia is offline
Sylvain,
D&F Propshafts supplied me the adaptor and a new prop on a 3 day turnaround. This was 18 months ago.
http://www.dandfltd.co.uk/products/propshafts/
Good luck
John W
Old 17th April 2013, 09:21 AM
Thank you John,
How much did you pay your propshaft + adaptor if I can ask please?
Old 17th April 2013, 06:15 PM
Originally Posted by voucht View Post
Thank you John,
£197 inc VAT and postage. Not the cheapest ! but needs must.
John W
Old 17th April 2013, 06:22 PM
Same company David
