Old 27th April 2013, 03:17 PM
Joelove's Avatar
Joelove Joelove is offline
Default Front shock brackets, book wrong again?
The two front shock brackets on the chassis, the centre holes should be 300mm from the base but the measurement from the base to top rail is 355mm minus 25mm for the thickness of the top rail minus 27mm for the sock bracket to centre hole = 303mm?
I know it's only 3mm but does this matter or do I need to fit a 3mm packer under the bracket?
Old 27th April 2013, 05:45 PM
It will make no difference really. 3mm here = about 1.5mm shock length difference and 3mm wheel travel. Tyre wear would account for more.
Old 27th April 2013, 10:17 PM
Joelove's Avatar
Ok cheers mate. Also what's the best way to line these up before tacking them?
Old 27th April 2013, 11:14 PM
I'm going to be using a length of metal from the lower wishbone mount to position it properly.
Old 28th April 2013, 09:50 AM
Joelove's Avatar
Good idea, I'll try that. Thanks joe
