Old 8th June 2013, 07:51 PM
Default 2.9 cologne air box?
May be one for Twinturbo/Robin but does any body know if there is an air mass/flow sensor on the underside of an EFI 2.9 cologne air box? I've seen the twin meters side by side on the Sierra but my engine came from a 1994 Scorpio and I'm thinking the reason it does not idle properly is because the system is not complete?
Old 8th June 2013, 10:15 PM
The photo is of a later 2.9 Using MAP sensor and Lambda Control.
Early 2.9 Used 2 air flow meters
Old 9th June 2013, 08:10 AM
P.S...
Check the Lambda sensor and clean the idle speed control valve.
Old 9th June 2013, 09:55 AM
Ah thanks for that I was looking for a part that was never fitted in the first place. I've cleaned the idle valve so I'll pull the MAP and treat it to a pair of new lambda sensors.
Old 9th June 2013, 05:35 PM
What car is the engine in?
Old 9th June 2013, 06:05 PM
Mk5 transit 190 chassis cab with adaptor plate to fit transit MT75 gearbox custom fabricated 40mm 3-1 manifolds in to 63mm exhaust and LPG gas kit.
Old 9th June 2013, 08:50 PM
London LEZ Here we come!
Old 9th June 2013, 09:05 PM
Sod the LEZ it's gone from 70hp to 130hp I've taken it around the yard and out in the damp with 50lbs in the twin rears and although it weighs 2000kg it drifts round large roundabouts like a bastard
