Old 9th July 2013, 06:05 PM
Wink Mx5 steering rack. Will it fit ?
Don't know if anybody can help at all please ? Will the mk1 mx5 steering rack fit the roadster please ? And also, in the gillham online mx5 build manual, it says that you can use mx5 uprights. But, this doesn't seem right, because the pictures show a suspension bracket at the top, and the mx5 struts have a single nut at the top. Any help would be really appreciated. These build manuals are really vague on the important stuff, and go into depth on the less important stuff.
Old 9th July 2013, 06:16 PM
The mx5 uprights are used front and back. Not sute about the seering rack but I have used an escort quick rack on mine.
Old 9th July 2013, 06:38 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
The mx5 uprights can be used with the wishbones as in the mx5 plans the mx5 strut is not used so the single nut wont be an issue
Cant say about the steering rack as I too am using the mk2 escort rack
Old 9th July 2013, 06:46 PM
Cheers chaps. Are you using coil overs on the mx5 kit then ? I was planning on using an escort 2.9 turn quick steering rack, but the urge to scavenge as much as possible from my mx5. I am just tight. Lol
Old 9th July 2013, 06:58 PM
Numplumb Numplumb is offline
I would like the answer to that as well, I'm using the mx5 pedals in mine to save money also pedals hung from the top as in most cars is more comfortable to use than floor mounted IMHO
Regards Mick.
Old 9th July 2013, 07:02 PM
Top man. Thanks for that Phil
Old 9th July 2013, 07:18 PM
StruveD's Avatar
StruveD StruveD is offline
My understanding is that the miata rack needs to be shortened by about 5.5 inches, to prevent bump steer. Don't know if you guys have the Keith Tanner book, but he goes into it in detail. I'm debating this myself, since the selection of OE steering racks that are right from the start is limited. But I dont know if I trust my welding skill enough for such a key piece of hardware.
Old 9th July 2013, 07:51 PM
See what phil says about it. Hopefully there is a really simple solution.
Old 9th July 2013, 09:17 PM
PorkChop PorkChop is offline
Shortening the MX5 rack, as said, is common in North America.
But they don't have a plentiful supply of mark 2 Escort racks over there. We do and they're not expensive new. You would also need to be careful as welding mods to the racks aren't allowed for the IVA or MOT; this is why rack extensions are screw-on rather than weld-on.
And the build manual that Andy originally wrote is to be used alongside the book, not a replacement.
Old 9th July 2013, 09:36 PM
The MX5 rack is about 7" too long for a roadster/locost so its quite a bit of work to shorten it.
Heres an example.
Doable but you need a fairly large lathe really.
