Old 14th July 2013, 09:51 PM
Default Crashed on the track
I've crashed my roadster!
Here's the video: http://youtu.be/V-S0JveBBsw
And here's the result:
From a preliminary inspection, RS1 has buckled beneath the wishbone bracket, and the camber adjuster has sprung a crack at the seam. The fact that all the chassis seams held is very reassuring :-)
Also, due to lack of clearance both the lower outlets of the thermostat housing have broken off on contact with the chassis.
I haven't gotten the roadster back home, but I'll post more photos as I go along fixing it.
Old 14th July 2013, 10:33 PM
Does the expression 'oh bollocks' translate at all?
At least the parts will be cheap to replace or fix, well maybe not the rim.
Old 14th July 2013, 11:39 PM
That looks like quite a large ditch to have at the side of the track! At least you are ok
Old 14th July 2013, 11:54 PM
PorkChop PorkChop is offline
Oh dear. At least you seem OK in the video, that's the most important thing.
Old 15th July 2013, 08:40 AM
I'm most impressed with the lack of swearing. I would have turned the air blue!
Old 15th July 2013, 09:08 AM
Oops its a good job your quicker with your fabrication than your film editing, its only taken 5 1/2 years to post it
Old 15th July 2013, 09:21 AM
So that's why you need a few bits from me. I'll get them packed and posted today. Looks like the backend lost traction as you came over the top of that hill turn. Glad everyone is ok.
Old 15th July 2013, 10:27 AM
I have one of those £20 cameras from the bay. It claims to support cards up to 16 GB, and I had a 32 GB one. For some time it appeared to have worked, but then the file system got corrupted. Maybe the impact had something to do with that, as the video stream had a glitch at the moment of the impact. I managed to extract the video from the corrupted card with a forensic tool (scalpel). I didn't get around to playing with the broken card for a couple of days, I thought I didn't have the footage of the accident at all, that's why it took a while.
CTWV50, both rear arches had by then lost pieces of gel coat due to voids in the edges anyway (yay NTS), so I was already contemplating strengthening and repainting them, after the crash it would just take more GRP and body filler. But having structurally sound ones to start with is better. ;-)
David, yes, the track is hideously dangerous, but that's the only one we have in the country.
Old 15th July 2013, 01:09 PM
Bad luck Albert. Looks like good fun up until that point!
At least having built the car you're in a good position to be able to fix it without too much trouble!
Old 17th July 2013, 05:25 PM
good to see your not hurt at least the car fixes quicker .
