Old 30th July 2013, 08:59 PM
Josh's Avatar
Josh Josh is offline
Default Roll Bar
Hi everyone
Is anyone supplying a roll bar? I only need the main hoop, already got the plates and I'll cut/weld my own harness/rear stay tubes.
Thanks
Josh
Old 30th July 2013, 09:24 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Try sending phil at talon a message he will sort you out
Old 30th July 2013, 11:49 PM
mikemph mikemph is offline
We at hamlet engineering can also help with rollcages
http://m1kemph.wordpress.com<---- build blog clicky
Check us out on facebook. Hamlet Engineering Services limited
Old 31st July 2013, 11:34 AM
Can you do me a roll bar in 47.6mm OD x 2.64mm wall CDS Tube rather than ERW?
Old 5th August 2013, 06:38 PM
Josh's Avatar
I am planning on making my harness tube, rear stay tubes (and probably a cross-brace in the main hoop) from the same stuff as my local steel stockists can only supply in 6m lengths.
Should I go for 1 1/4 or 1 1/2 diameter? 18g, 16g or 14g wall thickness?
Thanks!
Old 6th August 2013, 08:15 AM
I spoke to a former SVA/IVA tester and he said he personally would like to see the seat belt mounts be able to lift the weight of the car.
His personal view,not that of VOSA !
Make them overly strong you wont go wrong.
Old 16th August 2013, 10:29 AM
Josh's Avatar
After much internet searching I found a company called Wisbech Engineering Ltd, based in Norfolk. They made me a main roll hoop from 41mm diameter 2.6mm wall thickness CDS tube (41mm is the largest they can bend). They also supplied me with three lengths of 35mm diameter 3.5mm wall thickness tube to make the harness support and rear stay tubes.
Very friendly people, top quality work and fast turn-around (ordered it Tuesday, arrived this morning). Total cost including labour and P&P £169. Highly recommended if you're looking for a CDS roll bar as opposed to ERW!
One question however - I have enough length on my rear stay tubes to take them from the centre of each corner of the main hoop, rather than in line with the chassis rear stay bracket mounts (as per the book). I am considering doing this as it looks like it would resist side loading better, and I am thinking that I might upgrade my roll bar into a roll cage at some point - in which case my rear stay tubes would then line up with the tubes connecting front roll hoop to rear roll hoop. Any input/opinions on this please?
Josh
Old 16th August 2013, 10:52 AM
Josh
Thanks for the info I'll give them a call.
